clancy47ExplorerSep 20, 2015XM RadioI have a cab over camper on my crew cab F350. When I have it on the truck, I loose XM reception. Is there an extended antenna that you could install to connect to a ford radio?
mkirschNomad IISep 21, 2015So you tear the radio out every time you switch back and forth from the factory to the external antenna? Or, does it have easy access?
Related ContentSirius XM RadioApple car play or XM radioSirius/XM RadioSirius XM RadioXm radio interference
