valhalla360
Aug 19, 2023Navigator
Francis wrote:
Our windows are crank-out jalousies with attached interior screens so using a window is out of the question: we do not want to remove the whole window unit for a retro. The issue of draining the moisture from the A/C won't work with the window. Perhaps a bucket with a cover that has been cut for a hole to fit the drain hose. This works for us to drain gray water out to an enclosed bucket when necessary. We also have a portable dehumidifier but it is ineffective.
That's not an issue for a "portable" air/con unit. No need to remove the windows or screens. Also, most splash the condensate into a mist to send out side with the heated exhaust air, so no draining.
This doesn't work with a dehumidifier as there is no exhaust air. It pulls air out of the room, over the condenser and evaporator and then exhausts the now dryer air back into the room.
About Truck Camper Group
302 PostsLatest Activity: Sep 07, 2026
