StirCrazy
Aug 20, 2023Moderator
valhalla360 wrote:StirCrazy wrote:
THIS is a neat unit that I have been looking at. It's 12V and it's a heat pump so it replaces both your furnace and gives you an ac and draws just over 11 amps on full load. Best of all compared to other 12V AC's it's a little more affordable, but it would take a bit of work to install.
Steve
The link you provided goes to a 115v (per the website) unit.
Also, heat pumps are not great with actual cold temps. 40-50F, they do pretty well. By the time you get into the 20'sF, they lose a lot of heating power.
For the price of this unit, probably cheaper to get a standard RV roof mounted unit.
So it is, I missed that sorry, as for cold weather performance.. this one doesn't give spects so ya it most likely sucks, but lots can go down to -30C now days, they just cost a little more.. but seeing as this one is 120V its no good anyways.. weird as the link I followed was a 12V so I'll have to check that out and see if it switched me.
About Truck Camper Group
302 PostsLatest Activity: Sep 07, 2026
