I have OWNED both AF 811 2017 and EC 850 2015
THE BIGGEST THING WAS Eagle Cap
USED Azdel😀, a thermoplastic composite that’s lighter, stronger, and can’t physically rot
WERE THE ARCTIC FOX USED LUAN WOOD 🤔
one-piece cab over-the-nose (better sealing from weather )Advantage Eagle Cap
Thermal pane frameless windows (AF has dual pain but standard framed )Advantage Eagle Cap
rear step (TIE) the fox landing is very good
and the Adventurer’s Comfort Step
outside doors slam latches (just push and it closes) like higher end class Advantage Eagle Cap
Heki skylight arctic Fox you have to go through the side window Advantage Eagle Cap
center of gravity TIE both are 40 inches +/ -
Dry Weight AF 3,468 pounds EC 850 3,370 pounds TIE +/ -
AF Months 12 Structure Warranty EC Three-year structural warranty Advantage Eagle Cap
