Grit_dog
Apr 26, 2020Trailblazer
Thought you had your wheel wells stuffed with extra batteries?
Think about total cycles this way.
How many times you going to discharge it per year?
And how many years will you realistically have it? Appears you've had a multitude of RVs over the years. Are you going to need another "10 years" out of this rv and battery setup, for whatever reason?
Using 10 years as a baseline for about the longest you'll get out of a battery with good charging practices, care and a bit of luck, 700 cycles over 10 years is about 60-70 days of camping, draining and recharging. 100 cycles is 100.
Maybe it's 2 times a day if you're using a lot of power and spending your day firing up the genny multiple times to recharge. In which case you'll use up the battery before it dies of old age or misuse.
I'll throw out Odyssey batteries as the $300 each option that I've gotten the most life out of 2 different pairs of.
About Truck Camper Group
302 PostsLatest Activity: Sep 07, 2026
