FORD 6.0 Liter Repairing The Fuel Supply System
VIDEO: FORD 6 Liter Repairing The Fuel Supply System
I cleaned, blew out the fuel lines, installed a new Motorcraft fuel pump, and a FORD Blue Spring fuel pressure service bulletin upgrade kit made by International. I test the fuel pressure before and get less than 45 psi, after the new parts and blue spring kit, I got 65 psi. The PO262 code for Injector #1 went away, but the PO283 code for Injector #8 remains. It appears after repairing the fuel delivery system, I will most likely still have to replace the numbers 1 and 8 injectors. I have proper fuel delivery and the HPOP high pressure oil system is working properly. The FICM tests at 50.5 volts so that is most likely good. It may be that this engine ran with inadequate fuel supply which could have caused internal damage to Injectors 1 and 8. AT the insistence of the Unknown Mechanic I will go along with an experiment to see if ARCHOIL oil additive will restore proper function to the injectors. If no results within a couple days, I will begin to remove the valve covers and other parts to replace the number 1 and 8 injectors. I will replace the stand pipes and dummy plugs with the newer upgraded parts. I will also replace the high pressure regulator valve. There are no indicators that anything is at fault with the high pressure oil system but I will upgrade anyway as a precaution. I am open to knowledgeable suggestions and so will others reading this in the future. Thanks for your input.
New Motorcraft Fuel PumpUpper Fuel FilterFrame Rail Fuel Pump FilterOld Fuel PumpAccess To Fuel Tank PickupRear Fuel Tank PickupFrom 45 and Less PSI To A Solid 65 PSI
