To do it right you'll need to know the weight of the camper, the weight of the trailer with car and everything loaded - fuel, people, gear, water, food etc. Subtract this from the GCWR of the truck. Without knowing any of the above my guess is you'll be way over the limit. It's not just springs and tires. It's transmission, engine, frame, brakes etc.
- StirCrazyJul 16, 2026Moderator
I don't think I would worry so much about engine trans and brakes, well maybe a bit with the brakes, but for them your just going to end up changing them out more often. engine and trans, towing the big trailers and 5th wheels work the engine and trans way way harder than having it loaded up with cargo to the capacity, or a little beyond. I notice it big time when towing my 5th wheel then switching to the truck camper, I can only run the 35hp tune on my truck when towing the 5th in the mountians, with the truck camper I can run a 100 hp tune. also before the tunes, I get way way better fuel milage hauling the truck camper than towing the 5th, and the trans doesnt get as warm climbing hills. And, believe it or not it, actual braking is better also.
to me the most important thing your going to hit is the limit of the tires.
- way2rollJul 16, 2026Trailblazer
It's a 21 year old truck. I'd be concerned with everything I mentioned.
- ZondebokJul 15, 2026Explorer
Yeah, that's kind of the feeling that I have been having. He doesn't know those numbers, and I can't find a good way to estimate them. I'll probably just have to pass until I find something more suitable. Thanks for the help!
I would concentrate on finding a good truck first. if you can find a good used dualy for a reasonable price then pickign a camper after that is easy. heck if you have the dualy you could even go into a dealer and find a good camper for relitivly cheep, I was surprised how cheep I got mine for on sale and 2 years used. its always easier if you have more truck and can just load up almost anything you like and take it home.
