Bedlam
Jan 29, 2023Moderator
The fault issue with EMS is whether your generator has a bonded neutral to ground. Typically the generator is powering a RV or transfer switch at a home so bonding happens there rather than at the generator to prevent a ground loop and electrical noise.
They do sell bonding plugs for generators or yours may come with one. This is used if you are running tools or appliances directly off the generator so you have a safe return path during a short that will pop the breaker.
About Truck Camper Group
300 PostsLatest Activity: Aug 22, 2026
