otrfun
Feb 03, 2023Explorer II
deltabravo wrote:What you're describing appears to be the same scenario posed in my questions.otrfun wrote:Two things were at play:
P.S. deltabravo, is it possible you were experiencing more of an issue with your generator lacking enough inrush current to start your a/c compressor, rather than an issue with the PI EMS?? Sounds to me like your EMS was simply doing its job. The voltage dropped too low when your generator was unable to provide enough inrush current to start the a/c compressor, so the EMS simply cut-off power??
1. The E2 error, which I could overcome be flipping the switch on the EMS remote, which bypass that error.
3. The other issue was the lack of ability of the generator to provide enough surge power to get the A/C fan and compressor started. When that happened, the voltage would sag and the EMS would kick off the power.
When I finally decided to jettison the EMS, the generator started the A/C just fine.
If I would have had a Micro Air Easy Start back then, it would have likely allowed the A/C to start from the generator with the EMS installed.
I so have a Micro Air Easy Start on my AF 992 truck camper's A/C.
Flipping the switch on the EMS remote to the off position does prevent the E2 error; however, it accomplishes this by turning off *all* protection.
Interesting enough, even with all protection turned off, the EMS circuitry itself will shutdown (opening the EMS relay, shutting off power to the RV) if voltage drops much below 95-100vac. This is not the low-voltage protection being activated, it's the entire EMS shutting down from lack of power. I would guess this is probably what occurred in your situation.
When you removed the EMS, it allowed the voltage to drop extremely low without interruption while the a/c compressor started. It says a lot about your Honda 2000, that even with this huge voltage drop, it was still able to provide enough inrush current to start the a/c compressor.
Yup, I agree, a Micro Air Easy Start would have prevented both the voltage drop and the resultant low-voltage cut-off you experienced with the EMS.
About Truck Camper Group
300 PostsLatest Activity: Aug 22, 2026
