recycler
Jun 21, 2013Explorer
unbob wrote:recycler wrote:Should I use epoxy and wooden dowels - or forget the dowels and just fill the new drilled-out hole with epoxy and then re-drill for screws?
you could try west system epoxy it is some strong stuff...looked into it when i was designing a catamaran..
if the holes go into wood and the hole is close to orginal size expoxy with some filler should be enough.. they use the stuff to glue in the anchors for the cable stays for the masts on large sail boats..
About Truck Camper Group
302 PostsLatest Activity: Sep 07, 2026
