unbob
Jun 22, 2013Explorer
bigfootford wrote:Thanks Jim! Yes, I'm pretty sure you're correct about the backing plate. But I'm really worried now about it being displaced! I had not thought of that before. I just hope the backing plate is glued to the interior side of the camper wall.
From what I was told, the screws go through the Fiberglass and then into a block of wood/plate. You can confirm that by measuring how deep the actual hole is. The glass in the corners is very thick, maybe 1/8 to 1/4 in.. So if the hole is deeper than that you will know that there is a plate there.
So if they are not helpful then think about doing the following:
The best thing to do in that case is to drill new holes in the Jack bracket and then into the camper.
I would put the original screws back in the holes to hold the plate in place, just in case it is not glued to the inside... You do not want it to become displaced! Make sure you have enough holding strength to do this. If it feels that the plate is loose then you may need to do the following..
Fill the existing holes with West systems resin and filler, then drill them out to put the existing screws back in. Not much holding power but just for looking good.
My jack brackets are bedded in with silicon.
So when you have all your holes drilled I would remount the bracket without the bedding, then remove it if you are satisfied then use the silicon to bed-in and mount the bracket.
Jim
I will follow your advice but first I must get the plate "re-bent" since it "wraps around" under the bottom of the camper wall - there are 4 screws through the horizontal bottom part of the plate and 10 screws on the vertical part of the plate.
- JameydoshierAug 21, 2024Explorer
Can u use metal spreading anchors were the bolts had been ripped out when my jack stand basically did the splits with camper like a geraff bending down to drink water
- way2rollAug 21, 2024Trailblazer
You are responding to a topic that's 11 years old. You will probably have better luck posting your question/problem in a new topic.
- Both front jackstands at the same time slipped out away from the camper ripping the jack out of the camper on both sides
About Truck Camper Group
302 PostsLatest Activity: Sep 07, 2026
