SkiBumAt50
May 08, 2023Explorer
StirCrazy wrote:jimh406 wrote:
We didn't buy our TC to hang out in it all day. If we are going in/out, we have appropriate weather for the outside. So, we don't need it to be that warm inside.
Also, if we use our TC in really cold weather after winter, we don't use freshwater. Instead, we use RV antifreeze to flush. When we are winterized, we only need to bring it up to a minimal temperature just in time for sleep which takes barely any battery.
Finally, if we have at least power and winterized, we use our small electric heater, or our Air Conditioners heater element, and don't use battery or propane, obviously.
I'm not saying diesel is a bad option, but it's just one. We need propane in any case with a fridge, stovetop, and generator that runs on propane.
great, that's how you use it but it's not what the OP is looking to do.
personally, when I upgrade, I want tanks in the basement with the furnace heating the basement so I can use the tanks. Right now, I have been looking at the diesel heater option, only so I can extend my time out in early spring or late fall, when the night time temps are getting down to well below freezing. With my two 20lb tanks I can safely last 5 or 6 days. With an espar type heater that has twice the BTU output than my furnace I could extend that to over 10 days by carrying one 5-gal container of diesel, or indefinitely by plumbing it into my trucks diesel system. I don't camp with either of my units winterized, if I want to go camping I want to have full use of everything.
Yeah this is my intention. I like to cook. I like to travel. I've spent years camping in tents and lean-too's and now? I'm over that phase of my life. I'm looking forward to comfort now.
My local ski hill has overnight parking. I could easily park at the lot that you need a season pass to get on, hit first lift with my wife. Come back have brunch. Ski until lunch, maybe have an après-ski mid day and then my wife could go relax and read while I ski unitl they close the lift.
Alternatively I like to fish. Here in NY we have lots of state access where you can start fishing 30 minutes before sun up. Its easy enough to find a spot be ready and be at the spot quickly enough. You probably can't get away with staying at the spot (regs say for fishing only). But there's always a place to boondock close by.
You hit the nail on the head. I want to add a diesel heater as redundancy. Belts and suspenders so to speak.
LGMoon40
Sep 27, 2024Explorer
Problem with the diesel heater is that it won’t heat your tanks unless you make some mod to blow warm air into the basement where the tanks are located.
About Truck Camper Group
225 PostsLatest Activity: Feb 01, 2025
