Lancey
Jul 23, 2023Explorer
Oh, also, check the hose for your water fill spot on your left front, I seem to remember the hose going into the water tank from that leaking at bit at one point as well....turn on your water pump and see if it cycles every so often without use, and that will tell you if the fresh water system is leaking internally....you should be able to unscrew the plywood under the dinette to gain access to most of the components on that side
About Truck Camper Group
228 PostsLatest Activity: Feb 20, 2025
