retracted answer based on wrong information
- Grit_dogJan 01, 2025Trailblazer
Well that’s quite some clairvoyance considering the OP still hasn’t said which length bed he has and with virtually no info available on the defunct camper brand, we have no idea where the cog is, or how much it would affect the handling of the truck.
But by your conclusion, ALL these 10-12’ long TCs on 8’ beds are just horrible. Yet they’ve been making them for decades and continue to, without issue.
However, the OP isn’t really interested in providing enough info to get actual succinct advice so there’s that.- StirCrazyJan 02, 2025Moderator
retracted, based on wrong information
- mkirschJan 03, 2025Nomad II
Where are you getting your information on COG?
It's only 7.5', which is typically a "short bed" camper.
Even at 39", it's less than 6" behind the rear axle. That has the same effect as a trailer with no more than 100lbs of tongue weight. OP will hardly be doing wheelies down the road, even with a 3000lb boat in tow.
"OMG the COG is 1/4" behind the rear axle! It's a death trap!!!!" C'mon, be reasonable.
