egarant
Apr 19, 2024Nomad
Stable Loads
I topic beat to death probably, but I have a quick question. I installed a set of Torklift lower Stable-Loads this lifted the truck perfectly, but it took away the contact of the upper over-load spr...
The upper overload springs should not be engaging when empty but should when loaded. If you are still trying to address rear sag, go for the taller upper StableLoad pads. If you are level, there is no need.
