egarant
Apr 19, 2024Nomad
Stable Loads
I topic beat to death probably, but I have a quick question. I installed a set of Torklift lower Stable-Loads this lifted the truck perfectly, but it took away the contact of the upper over-load spr...
With the camper on the truck not loaded with gear/food/clothing/etc. The upper overloads are not engaged. When said gear is loaded into truck camper, they are engaged. I am trying to reduce side to side sway when going in and out of driveways……
Cheers,
you want them to be engaged with the empter camper put on the truck, I would look at the stable load uppers also. does your truck have a rear sway bar? if not that would be a big help also.
