egarant
Apr 19, 2024Nomad
Stable Loads
I topic beat to death probably, but I have a quick question. I installed a set of Torklift lower Stable-Loads this lifted the truck perfectly, but it took away the contact of the upper over-load spr...
With the camper on the truck not loaded with gear/food/clothing/etc. The upper overloads are not engaged. When said gear is loaded into truck camper, they are engaged. I am trying to reduce side to side sway when going in and out of driveways……
Cheers,
I skipped the lower Stable Loads, since I didn't think I would enjoy attempting to drill the springs. I installed upper Stable Loads (easy) and replaced both the skinny Ford anti-sway bars with Roadmaster bars. These two things helped reduce swaying considerably.
