Mar-01-2012 05:53 AM
Nov-22-2012 04:05 AM
From VW TDI wrote:
I was at local car meet this week and we had a new member come by because he moved in town recently and he is the TDI specialist now as one of the local VW dealerships. I was talking to him about the HPFP issue and he brought up that all cars that threw check engine light or stalled prior to the hpfp failing showed mbar difference between requested and actual pressure over (I THINK HE SAID) 150mbar. He was telling me that when he went to a class over the HPFP stuff a few months ago they mentioned that they are working on an check engine situation that would throw code when the pressure of fuel pressure showed degration of the injection pump within a certain tolerence and make the car undriable. COMPLETE LIMP MODE... as right now if the car throws code for crazy fluctuations in fuel pressure now you can still drive the car but the glow plug light will just pulse...
He said all vehicles that they seen 150mbar+ difference that they swapped HPFP under warranty never passed metal through the entire fuel system ruining it. He was saying if an gauge company was able to make an gague that displayed actual and requested fuel pressure difference it would be vital gauge. He said the pumps that were on there way out struggled to even make reuested pressure at idle yet alone any other rpm... just food for thought...
If anyone is good with electronics could make a simple display with a buzzer possibly to achive this may be able to save people thousands of dollars.
Nov-01-2012 06:46 AM
NewsW wrote:NinerBikes wrote:
Toyota /Nippondenso's approach to HPFP pump design.
The Nippon Denso approach can do much less volume, harder to add capacity vs. the CP4 (which can just add cylinders.
http://www.globaldensoproducts.com/em/dem/crs/supply_pump.html
Much more expensive to manufacture.
Good only to 1,800 bar (a lot less for the higher volume models).
But it is much easier to design hydrodynamically.
Would like to see what coatings it has.
How is it lubricated? Is it fuel in the whole thing, or is it lubricating oil on the outside loop? The photo suggest it is fuel lubricated.
Note it is paired with solenoid injectors that are probably much slower than the piezo electrics:
http://www.globaldensoproducts.com/em/dem/crs/solenoid_injector.html
Nov-01-2012 03:41 AM
Oct-31-2012 01:45 PM
BenK wrote:
If you get another chance to see the parts, could you take some pictures?
Am mainly interested in the pump innards and on that, the piston bottom/cam follower/cam face.
Is this one with the DLC only on one side? Anyone know if cam face or follower?
Can someone post a cross section of this pump? IIRC, there is a roller in the
cam follower, or am I mixing it up with something else?
Such a low miles and hours makes your components extremely valuable for diagnostics/forensics
Now that there is more info, albeit still a small sample size, am now convinced
it is inside the pump cam cavity.
What mechanism(s) of failure is/are still up in the air for me
Trail telltales for me are: The addition of DLC to both surfaces, the
change to only one sided DLC, the ever constant H2O warnings or that
they look for that first (is that just a ploy, or real), that this
is across many badges and engine sizes.
Also, if you can either scan or type in the work order info. *ALL* of
the parts listed might be telling. So will be EACH task. Maybe the
order/sequence important
Will they give you the parts? If so, are you into photography? If not
would you send me the part(s) and I'll take some high res close-ups
and post for forum discussion.
Did that for the GMT800 receiver where one forum member had it actually
break off. Most thought pieces were gone, but after taking a few
hundred high res pictures, was able to put it back together and
actually sequence the stages during the failure that eventually
lead to the part tearing off. Only had the receiver pin box and
only images of the receiver cross tube 'hole' vacated by his pin
box, but it all went back together visually after taking closeups
of mating separation edges (bent & mangled at that)
Oct-31-2012 12:46 PM
LastOfTheBohicans wrote:
I wanted to post a quick update.
I have the work order from the dealership regarding the repairs. It lists the part numbers (Ford) and all the work steps.
I was able to find out that the pump was from Germany and the tech said that it was the Bosch 4000 model. I don't know if this helps you but like I indicated I will post the Ford part numbers.
When you ask?
When I get the truck back as they still haven't fixed the P20BA Reducdant Heater issue that I brough to their attention 2 weeks ago! Sorry, blood pressure spiked there for a second.
Oct-31-2012 11:27 AM
Oct-31-2012 11:06 AM
Oct-25-2012 05:55 PM
Oct-25-2012 04:52 PM
Looks like they are calling it the new HPFP CPN5 series and it's got a very, very long commercial application life rating... that's gonna be expensive....
What bothers me is the CP4 appear here to stay for a while.
There is no major redesign beyond what they already did.
Look at the size of the medium-heavy duty version.
I wonder if it is oil lubricated.
The gossip in the trade is the piezo injectors are too expensive and the next move will be to go back to HEUI.
Oct-25-2012 03:46 PM
Oct-25-2012 03:32 PM
NewsW wrote:
Have a latest look at the CP4.
It is now got a 2,500bar variant.
http://www.dieselnet.com/news/2012/08bosch.php
Plus, have a look at the larger cousin.
http://www.bosch-kraftfahrzeugtechnik.de/media/db_application/downloads/pdf/antrieb/en_3/05_DS_Sheet...
Note the claim for life in the above...
Oct-25-2012 02:09 PM
Oct-25-2012 01:32 PM
EPA has declared invalid 140 million RINs representing about 930,000 gallons of biodiesel. Oil companies use the credits to demonstrate compliance with the Renewable Fuel Standard, which requires them to blend a certain amount of ethanol, biodiesel and advanced biofuels into US motor fuel supplies every year.
Oct-25-2012 12:56 PM
NinerBikes wrote:BenK wrote:
Yes, and wonder out loud what the 'spot' temperature is at the cam/follower
surface?
Betcha it is way up there...
All that is missing are trace amounts of sulfur, along with free O2's. The
PSI's & temps can make some very nasty acids...
All being churned by the cam and follower and another betcha that there is
electrical current running amok between parts inside the cavity
Take a refresher course on how biodiesel is chemically made... methoxide, sodium or potassium hydroxide in the form of lye and methanol being blended, to strp the glycerine backbone/fatty acids off the vegetable oil, to be replaced with methanol alcohol. What acts as the catalyst for this chemical reaction? What would be the residuals left in biodiesel? What happens when you wash the fuel with water to remove the excess residual methanol? What happens when the fuel is improperly dried completely, which takes a lot of heating to drive the moisture out, making it cost ineffective? :S Is not methanol a free source of oxygen in your fuel? What about residual catalyst left in your biodiesel... what kind of catalyst is it inside your high pressure fuel pump for other undesireable chemical reactions taking place? I am asking, I don't know the answers, nor am I implying that there is a good answer.
Oct-25-2012 12:22 PM
surface?
