MarkTwain
Apr 02, 2020Explorer
Crowe wrote:
1. Book your campgrounds in advance by calling each of them. That way you will know for certain but understand it may change.
2. Check with each individual state you will be crossing through to see if they have checkpoints when you go in. Some states are requiring you "check in" and give them personal info as to your plans. If you aren't staying in that state you should have no issue. GA, however, now has a shelter-in-place order as of 4/1.
3. If you think you may have to boondock or be there for a while it might not be a bad idea to get a generator. If you can stay at established campgrounds you shouldn't need one.
4. Snafus? Yes-check with the hospice center to ensure they are allowing visitors. You are adding additional risks to yourself if you stop to get gas, groceries, etc. You can mitigate that risk by following CDC protocols and wearing gloves when you get gas.
Good luck!
Good advice! Has your family member been tested for the virus? what were the results? If they positive , they may have to
be quarantined.
About Campground 101
Recommendations, reviews, and the inside scoop from fellow travelers.14,716 PostsLatest Activity: Oct 15, 2013
