soren wrote:
az99 wrote:
soren wrote:
I was a home builder in a wet, wooded region where crawl spaces are common, and winter temps. might go to zero on rare occasion, but typically lows in the teens are more common. I have seen unheated vacation homes with cracked and bulging foundations, and even frost that worked it way deep under the structure and heaved column pads upward a few inches. Now, you are spot on with regard to damages likely in extreme cold, but don't forget frost needs three things, low temps, moisture and conditions that retain moisture. I can assure you that in our wet clay soils we have three of three. When my new homeowners tell me, "We are planning on shutting the heat off in the winters" I'm pretty blunt.
I tell them to expect drywall damage, to be aware that structural damage due to frost heaving is a possibility, and that I don't warranty poor decisions.
How were you allowed to or why did you build a structure where the footings for the foundation were not below frost line?
Massive presumption on your part. All my work far exceeds code requirements, foundations are done well beyond minimum requirements, and I failed exactly zero inspections, which is pretty unusual after a few hundred of them. As for my observations, It's important to note that there are plenty of events that can happen to an unattended building, and as I have seen several times in the past, clogged, missing or damaged gutters, and several weeks of wet freeze and thaw cycles in a mixed climate like ours can really do some damage to a foundation.
Absolutely agree with soren's comments! For the comments on seasonal cabins without basements, it doesn't really matter if the cabin receives some damage, it's an easy and cheap fix. For those of us with basements it's a different matter. It's easy to get wall damage given the power of the freeze-thaw cycles (none of you folks have any potholes and bridge/road damage in your areas do you?).
I note the $$ spent in the post above to prepare a home for a winter without heat, it's about the same as heating our home over the winter.
In terms of potential damage and costs, our home insurance deductible is $500, a bit less than the annual winter heating costs, I'm wondering if the insurance company would pay a substantial claim for foundation damage when you don't heat your house over the winter??
