  • Yes...we've used it many times on hand-pumps at NFS sites. Often you'll have to sit and hold it on, but it works.
  • No filters just filling a jerry can and thought it would be easier than trying to get the water in the can with the thief and short hose. Thanks for the replies.
  • Gjac's avatar
    Gjac
    The water thief will expand like a balloon if you have water filters that are restricting the flow. A cheap filter actually works better because it allows more water to flow through. I have evolved to several home made hoses with hose clamps that will fit most of the pressurized water sources at NF and NP CG's.
  • We have used a water thief with a pump with one person (me) holding the water thief onto the spout while DW pumps the water into a jerry can. Not as elegant as a hose clamp, but it does the job fairly well, if the pump pressure is not too high.
  • In addition to a hose clamp I use a fairly long strong ny-tie through the clamp and over the top of the faucet. The thief is slippery when wet (-:
    Jim
  • Ok thanks I wasn't sure but looked like it would. Ill let the wife work the pump lol. I will fill water containers in town when I can. I just have a 20 gal fresh water tank on the trailer, just 2 of us we can get a few days out of it. We do it all the time at the deer lease.
About Campground 101
Recommendations, reviews, and the inside scoop from fellow travelers.14,719 PostsLatest Activity: Mar 01, 2025
