Yellowstone with no hookups?
Pbois334
Staying in Yellowstone for a few days witth our travel trailer and they do not have hookups. There is water at the campground and a dump station. We currently only have one battery and II was thinking of adding a second battery? I have a wagon to take care of the dumping. Should I get a generator to charge the batteries or should they last the three days? Also, not a fan of the loud furnace. Would I be able to run a ceramic heater off the batteries if needed? First time camping without full hookups and want to be somewhat prepared. Any advice would be appreciated
27 REPLIES 27
ppine
I agree with bionic man. Making coffee warms up trailers a lot. So many people make a big deal out of boondocking. People think "they are not set up for it." You still have propane appliances and can run the water pump. With LED lights you are good. It is really just running the furnace and the AC that are a challenge without a generator or solar.
Camping in the park saves the long commute. You are right there with the wildlife. Totally worth it. I like spring and fall best.
monkey44
Nomad II
Nomad II
We've camped in Yellowstone even when it got a light snow overnight ... We just turned on the heater, go everything warm, turned it off, wore long-johns and sweats to bed, extra blanket too. Then flipped heater on in the AM, warmed it up a bit before we got out of bed. Works fine. We could go three or four days easily on one battery. Don't run heater all night and you should be OK.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
dieseltruckdriv
Make sure you get the more expensive catalytic one that states it can be used inside, and make sure you run it on high for a tank of propane before using it indoors. They have a strong odor when they are new. Probably oils etc. from manufacturing. It goes away after a little while.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
Pbois334
I was thinking about the buddy heater. How are the fumes with those?
Bionic_Man
Add the 2nd battery. Get a Mr Buddy portable heater. And you wonโ€™t need the generator.
Heater
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
BarabooBob
According to the weather service, the low temps in June should be 38 and July lows should be about 45. You will need some heat but how much you run it will determine your battery life. We set our furnace at 50 degrees overnight and throw on an extra quilt. The furnace only runs a couple of times every night. I recently purchased a Champion 2000i for topping off the battery every day. I should not have to run it very long.
I recently replaced my brand new WFCO converter with a Progressive Dynamics converter because the WFCO would not go into the 14.4 volt rapid charge mode, even when the battery was low to start. After reading about the failure rate of WFCO's, I decided not to bother with the warranty and with what I knew. I had a PD in my last RV and loved it, fast charging and low lost of battery water.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
DrewE
Average lows during the nights are around 40 degrees in early July, according to Google. A heavy blanket or two would go a long ways towards keeping things comfortable (or at least bearable) at night without needing much if any furnace usage.
Lwiddis
Some reading about available amp hours in your battery and the amp hour draw of a even modest electric heater (plus the loss for an inverter) should be your near future. Three days of conservative water use shouldnโ€™t force dumping unless you taking an army. Many of us are dry campers/boondockers. You can have a great time even if not in an RV hotel. Last, Iโ€™m a solar guy but a small backup generator comes with me on every trip. Havenโ€™t needed it in the last 6 months but it comes along.
Pbois334
We will be there july 3rd. Prob still cold at night. I wil def add the second battery and have been looking around for a Yamaha or Honda generator. The furnace will suffice as heat source. Excited for the trip but a lot to plan for. Three days in Yellowstone and three in grand Tetons. All part of a 21 day trip from RI
westernrvparkow
Ceramic heater run off an inverter will deplete the battery very quickly. The only heating option that will potentially last a night would be the propane furnace. As for a generator, all Yellowstone campgrounds restrict generator hours at a minimum, and some do not allow them at all. You will want to be sure you get an inverter style generator because they are much quieter than an open frame contractor style.
HadEnough
You definitely can't run a ceramic heater off a battery.
You'll need to use the furnace, like it or not. It takes 1200-1500 Watts to run a ceramic heater. That's a minimum of 100 amps per hour at 12 volts. How many amps in your battery? Remember also you can only really get 50% of the rated deep cycle anls out of a battery.
Based on everything in your post, you should get a Honda EU2000 generator. Yo can run the ceramic heater off that. Plus charge your battery. And it's fairly quiet.
DrewE
What time of year are you at Yellowstone? How cold do you expect it to be?
As a very, very rough rule of pinkie, one battery equals one night of furnace usage, at least in my mind. Obviously that depends a lot on the battery and the temperature; if the furnace is running more or less constantly it will use a lot more power than if it comes on for a few minutes every half hour or hour.
I would suggest getting the second battery, though it may well be possible to manage decently without it if you don't need too much power and the weather cooperates. You still may need to use the generator to recharge once or twice. If you don't have a multistage converter, that can be a quite slow process.
I also suggest getting something to monitor the battery state that's more accurate than the typical three light indicator panels most RVs come with. A panel mount voltmeter is a very big improvement; a trimetric or similar is even better but also a good bit more expensive.
Tom_Barb
A small generator is a good idea. we even carry one.
