SkiSmuggs's avatar
SkiSmuggs
Adding 12V Receptacles
I would like to add some 12v receptacles and first thought I would have to run wire (still not a bad idea and I will come back to that), but it was suggested that I could tap into a nearby 12v light fixture. I am all LED now so I am not concerned about overload. So I can use the BR reading lamp to add a receptacle near the bed for my CPAP, and I can use a light over the sofa to add one there. I would also like one at the LR entertainment center for a 300w inverter to power TV and DVD player, but there are no lights there and am not sure if I should use the Jensen power wire or not. Any suggestions for that or about the plan in general.
My issue with running good 12v wire is I am not sure how to run that through my fiver and I am not sure how to connect to the battery. Direct battery connection of several wires doesn't seem like a good idea and it seems the existing wire runs to the converter at the back of the trailer. And would I need to run both a hot and ground wire?
Feel free to chip in on whatever topic you feel comfortable with.
Thanks
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 14, 2026
