jimh406
May 22, 2016Explorer III
Adding an 12V outlet to a slide
I'd like to at least add a 12V outlet to one of my slides inside a cabinet. The goal is to minimize a long extension cord from my only other 12V outlet that is about 12 ft away. I expect I would only need to run no more than 10 ft of wire from the battery.
A secondary thought is to add a larger inverter and hardwire it in the cabinet that is open at the top. Since I only plan to run a small tv and dvd player and other tiny appliances like maybe charge a phone, I think it's probably overkill to add a larger inverter. Instead, I'm thinking of using a small inverter that plugs into a 12V power outlet.
I haven't been able to find any rule of thumb for how much extra wire I should include or how to secure it. The slide only moves 18 inches. I might be overthinking this, but in any case, I want to make sure before I start cutting to add an outlet.
Any other hints or examples would be great.
