lovetotow's avatar
lovetotow
Adding support
I have a crossroads cruiser that I want to add a strong arm support frame to, belly frame is enclosed and the spare tire is an underbelly mount right at the front edge of the lower deck. How can I find the metal cross beams at the front landing gear and also near the back at rear support legs. Will I have to find a new place for mounting the spare. Thanks in advance
  • rhagfo's avatar
    rhagfo
    Got pictures for the tire mount.
  • I installed BAL lock-arm struts. Could not find anything between the I-beams to mount to so I mounted the upper bracket to the underside of the bumper. Works very well and provides side-side and also fore-aft & vertical reduction in movement. I mounted a short length of 2x2 steel to the bumper, then the bracket to that. I haven't installed any struts to the stabilizer (electric) jacks at the front as just adding ones at the rear has made a big improvement and don't think adding one to the front will help all that much.
    Can you post photos to give an idea what the challenge is?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
