Spray Foam (2 lbs / medium density) Closed Cell "contractor grade" within RV walls, ceiling and underbelly is an amazing product. If wondering, I applied 3-4" under my 2006 TT and am very impressed with its before and after results. Not only did it create 7.5 R "per inch" with vapour barrier, Contractor Grade spray foam also tightened up its floor movement. IMO, Spray Foam insulation should be minimum factory build in all RVs - just like housing industry is realizing that Spray Foam in outside house walls is a great thing as well.
Lessons learned:
- Stay away from those diluted DIY Kits - like Tiger and other companies. Only use Contractor Grade foam.
- You can tow your RV/TV to their spray booth. Or, you can ask them to visit your RV location with their mobile truck. Either method works great.
- To reduce costs, do as much before preparation tasks yourself. Simple DIY stuff like taping plastic sheets on the over spray areas. And, ensure inner wall wires / PEX piping is in excellent condition (before spraying). And where needed, created access door boxes - where one might need access (like behind the tail light assemblies (to change a blown bulb from the inside).
- To reduce costs, do offer clean-up tasks as well. For example, you remove overspray plastic sheets, you clean up the over spray droppings, etc. etc.
- Ensure all needed speaker wiring, 12 volt wiring, electrical wiring, etc. etc. are installed - before Spray Foaming task as well. If you think wiring might be replaced or pulled in later on, simply install some 1/2" flexible PEX or PVC plastic piping and if needed, use wide smooth corners. Thus, one can "fish" replacement wires to that specific spot (like TV/DVD/Media Player) later on.
For a good video showing contractor spray foam in a Sprinter van, surf:
- click here - For good video showing contractor spray foam in large box van, surf:
- Click Here - To view the spray foam (contractor grade with their mobile truck) under my 2006 Jayco, surf many pictures within:
- Click Here - Would I install "contractor grade" Closed Cell Spray Foam 3"-4" thick under my RV/TT again? YES. Without hesitation!!! Amazing upgrade with amazing results. Especially since we plan to keep our 2006 Jayco 29ft RV/TT for 5+ years.
Note: Do shop around because prices for same contractor grade spray foam does dramatically vary. I found one local company at nearly 1/2 the cost of others. And, he didn't charge me travel time (because my RV location was on the way to a very large job).
If there's a wide 18" inner wall cavity that has smooth surface (re: no spots for the liquid foam to stick to), simply install some galvanized wire mesh. Same galvanized wire mesh (available at many home hardware type stores) that's used on rabbit cages. Then, spray foam over this wire mesh. Vision same effect as steel re-bars in a cement floor - before pouring the liquid cement on the floor.
Hope this helps.
