TNGW1500SE's avatar
TNGW1500SE
Any tips on re-carpeting doghouse?
My doghouse carpet in trashed. I'm taking the old carpet off. It's glued on really well. I'm having to cut it loose with a vibrating saw. Regular carpet doesn't want to bend to fit the curves. I'm thinking of trying a heatgun to warm the new carpet up to shape it. Any advice?
  • I've put carpet in vehicles. A lot of it can be cut or formed as you go but templates are like gold, just allow for extra.
    If the carpet is jute backed, a spray down of water will loosen it so forming is a snap.
    If the carpet is plastic backed or has a pad attached, heat can help but pressure and fastening while the adhesive sets is more typical. You can also fold or roll some plastic-backed carpet to loosen it before installation. All carpet has a weave and weft (backing is laid in two opposing directions) so work it in two directions.
    If you have a carpet with dense pad, you may have to make some cuts in the pad to form around tight radiuses (radii ?).
    Good luck with the installation!
  • How you carpet your doghouse is kind of a personal thing. German Shepherds generally prefer utilitarian carpets, being they are working dogs. Afghans obviously prefer Oriental Rugs. And a Shih Zhu would probably need a toilet paper motif.
  • Gjac's avatar
    Gjac
    You wont be able to form the new carpet over the doghouse be heating it. The best way is once you have the carpet removed use it as a template to cut the new carpet. Carpet can't be formed over compound curved sections only single curved or wrap sections. The original installers know this so they made the cuts in the right places.
  • Thick trunk liner should work.
    https://www.amazon.com/Automotive-Trunk-Carpet-Medium-Speckled/dp/B006320UKY
  • Use a heat gun to loosen the old carpet. you don't want to gouge the fiberglass dog house with a saw.
    As to the new carpet, lots of cutting and trimming to make it fit.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,370 PostsLatest Activity: May 11, 2025
