- rhagfoExplorer IIIThe biggest issue with a permanent mounted antenna is getting a clear view of the southern sky. In the PNW that could be an issue.
- Bill_SatelliteExplorer IIThey are designed to be in the sun and the weather and will hold up for years and years, exactly the same as the units designed to be roof mounted. They are made with the same material. If you figure a way to safely mount it (see if a ladder mount might be a possibility) it will be fine.
About DIY Maintenance
