Old-Biscuit
Oct 24, 2018Explorer III
garyemunson wrote:
I was going to have them blow out the top at first but noticed that I'd have to reverse the blades for that to be efficient (and reverse polarity). Thought I'd try the top down first. When the snap disk doesn't turn them on, convection will do the cooling (bottom to top). I really do not think it is going to make a difference when they are on considering the amount of air they are moving. Individually the fans draw about 8 amps and are far too noisy and move much more air than is needed. In series they work just right for me and use 1/2 the current.
Can't you just turn fans around?
And they may enhance cooling due to size/CFM of fans BUT
NO...blowing air down top to bottom is NOT how an absorption fridge gets rid of heat.
But it's your fridge ---have at it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
