Boddhisattvha's avatar
Oct 25, 2016
Help with our Furnace Please
Hey Everyone,
I have a 1984 Hi-Lo and our furnace has stopped working. The furnace is actually only a couple years old as I had previously replaced it. The furnace is a Suburban NT (I don't remember if it was 16 or 20).
The issue just started one day. Turn on the thermostat and nothing happens. So I checked the breakers, they were flipped. Checked the fuses and one was bad. Fixed both issues and still nothing. No blower motor, nada.
Any ideas on what I should check? I'm really not wanting to put another furnace in.
Any help is greatly appreciated.
  • Thanks so much for the responses and the link gentleman. I am pretty sure there isn't power to the furnace. There is power to everything else in the trailer. Given that the fuse was blown and the breakers tripped I am guessing something went sideways. I guess I will have to break out the multimeter and start at it that way. Thank you much!
  • Batteries? You need 12 volt power for the thermostat and controls to work.
  • It sure does sound as though the furnace isn't getting power or the thermostat isn't properly calling for heat. Either one should be fairly straightforward to check with a multimeter. I'm assuming you otherwise have 12V power available in the RV--that is, the lights work, etc.; if not, then that's your more basic problem.
  • Bryant RV Services has posted service manuals online.
    Yours is probably at
    http://docs.google.com/viewer?url=http://direct.bryantrv.com/docs2/docs/ntseries.pdf
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Dec 11, 2017
