โMay-15-2016 07:53 PM
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
โMay-17-2016 07:38 PM
โMay-17-2016 05:26 PM
1971duster340 wrote:
I've been researching, talking to a friend for some time that is quite knowledgeable about LEDs. I want to replace my halogens also. He gets his from Asia and has good luck with 12V auto use and know which brands are junk. I'll pass on what I learn.
I am staying away from LEDs that handle both ac and dc and the variable voltage type, 12v dc only. The more dedicated for a certain use, the better. I think 35 LEDs with transformers would be an RF noise disaster.
โMay-17-2016 05:09 PM
โMay-17-2016 03:48 PM
โMay-17-2016 11:09 AM
bobrizer2 wrote:
Word of warning. IF you replace that G4 bulb with a high quality led bulb, you can forget about watching TV on your bat wing antenna when that light is on. I replaced mine only to discover that the more expensive leds contain a voltage regulator that emits an rf signal that will blank your tv signal. Google leds and tv reception for more info. Then buy the very cheapest leds you can find. This apparently doesn't happen with every brand, but you won't know until you try.
โMay-17-2016 10:41 AM
โMay-17-2016 10:21 AM
โMay-17-2016 07:51 AM
โMay-17-2016 07:36 AM
1971duster340 wrote:2001400ex wrote:
Here's the pics. Are those the correct bulbs? I want something in the range of 5k rather than 3k tho. Any recommendations?
Without knowing the diameter of the lens or fixture part #, can't be answered. There are two different fixture sizes in our camper...the G4 bulb fixture lens is 3"dia. The GY6.35 bulb goes with a lens 4 1/4"dia. The fixtures are identical except for lens size, so a photo is misleading.
5K is cool light...3K warm light.
You're getting there by not cracking the lens and loosing a finger.
โMay-16-2016 11:16 PM
โMay-16-2016 09:29 PM
Lazy D wrote:
Looks a lot like mine. That lens should just pull out. It is real tight. Held in with a flat spring type retainer.
Mine are a G4 bulb.
Something like these might work for you.
http://www.amazon.com/dp/B00W1038SS/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=36HHYDB8CCEAG&coliid=IY3QGR26E8B3C&psc=1
Please see sticky at the top of the forum about posting pictures.
โMay-16-2016 06:40 AM
brirene wrote:
How many rv.net members does it take to change a lightbulb? To be determined...
โMay-16-2016 06:39 AM
โMay-16-2016 06:35 AM
