Installed my fireplace.
gaymeadowsman
I installed an electric fireplace in our Avenger 27RLS this weekend. I placed it in the entertainment cabinet under the TV/Stereo.
John ๐Ÿ˜›
Ted :R
in search of the next one
2010 Chevy Silverado Ext Cab LT
2015 Chevrolet Impala LT
11 REPLIES 11
camperfamily
Be careful with the double ended male cord. Known as a suicide cord. Someone who doesn't know better could kill themselves. They make power INLET boxes for just that application.
Someone had to say it... nice work otherwise.
2011 Cougar 322QBS
2007 Pilgrim 278BHSS (Sold)
2023 F359 CCLB 7.3
2013 F350 CC LB 6.7 (Retired)
2002 F350 CC LB PS (Retired)
B&W Companion Hitch
RollandB
Thanks. Excellent price you found
2013 Yukon
2021 Coachmen Spirit 1943RB
gaymeadowsman
this is the fireplace that I bought, the reviews were good, and the price of 149.99 was hard to beat.
Fireplace link
John ๐Ÿ˜›
Ted :R
RollandB
GMM, thanks for the explanation, that is exactly how I am thinking of doing ours. We have an outlet close by that is on a 20 amp circuit and an unused 2nd AC circuit I could use if I wanted to run it through the trailers 110 side but would rather do as you did. Which make of fireplace did you go with? Again, nice work!
2013 Yukon
AllegroD
GMM
Ours, factory installed Dimplex, Allegro 36LA, has return air at the bottom and exhales at the top.
Very nice work.
gaymeadowsman
Old Duck, I actually have the fireplace set up so it can be pluged into an external source, from the camper. I installed an outlet in side tha cabinet, wired with 12gauge romex 3-strand wire. I ran the wire through the enclosed belly of the trailer to come out below the trailers power cord and installed a second outlet(GFCI) enclosed in a waterproof power box.I have a 10 gauge power cord with 2 male ends that connect to the power pedestal and the external fireplace connection.
I ran the fireplace/heater for an hour this weekend and there were NO hot connections anywhere, and no CFCI trips.
John ๐Ÿ˜›
Ted :R
gaymeadowsman
My daddy didn't raise no plumbers. :B
John ๐Ÿ˜›
Ted :R
Mike_LeClair
That looks very awesome! And thanks for sparing us any plumbers crack in the one pic.!
Mike
Something Old, Something New
2012 F350 SRW, 6.7l Powerstroke, 3.55's front and rear.
2008 Fleetwood Regal 325RKTS
Mike, Carol and our 4 legged "furry child" Kenzie Shweenie Tod
RollandB
Nice work, I like how you used the simulated brick panels for its trim. We are looking to do the same so am curious if your unit runs on 15 amp and if you have it plugged into its own circuit.
2013 Yukon
gaymeadowsman
We walked though a lot of campers with fireplaces in them and I noticed that none of them had a cool air intake on them(that I could see). I know my cabinet had that BIG hole in the wall,but I wanted the fire place to draw cool air from the living space,not from the under belly of the trailer. I covered that hole before I set the insert in place and made the intake under the the fireplace. I think the heater and wiring will be safer.
John ๐Ÿ˜›
Ted :R
RoyB
They certainly give a very nice visual display. I think you will find it very nice to have warming up your feet first thing in the mornings. I would only run the electric heater lower than full setting. Those are prone to melt your wiring .
You can run the visual display with having the electric heater running which is a good idea as well...
I saw one recently where the owner had a fire burning display on his large TV setup. That worked too haha... warnm and Cozy...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
