- nremtp143Explorer
ICamel wrote:
Most screen doors have a channel on the inside around the door areas. If you have a piece of Lexan cut to fit inside those channels the Lexan material has enough flex that you can fit it in. Then use some window screen vinyl spline rope to hold it in place.
That's what I did on both of my Sandpipers, but the door of my Montana is a little different and may have to try a different approach. - bowebowExplorerLowe's by me in Florida carry's bronze color plexiglass. I had them cut it to size, so it would fit in door channels. Had to radius 2 corners, used a sander, worked good. No clips, fit nice.
- Bucky_BadgerExplorerWindow clips really well. Easy to remove plexi any time. All hardware and home centers carry them
https://www.menards.com/main/search.html?search=window+clips - ependydadExplorerIs there a lip? It would be fairly permanent, but couldn't you use caulk like it's a glue?
- DennisG9ExplorerMine came with plexy on it. Its mounted with small sheet metal screws and small fender washers.
- rockhillmanorExplorerAll you need to do is pick up mirror holders. They are on a screw with a small lever that you pull down to put plexi in and then flip the lever up. Easy peasy. All of about $5.00 for a pack of them.
- John_BettyExplorer
That's what we did but never thought of the spline rope. I guess another item to add to the to-do list. - phillygExplorer IIAnd, Lexan was developed by NASA and doesn't yellow like plexi-glass.
- ICamelExplorerMost screen doors have a channel on the inside around the door areas. If you have a piece of Lexan cut to fit inside those channels the Lexan material has enough flex that you can fit it in. Then use some window screen vinyl spline rope to hold it in place.
- myredracerExplorer IIDon't know if screen doors are all the same but with ours, you can take the frames apart by removing screws. The screen material sits in a frame about the same thickness as plexiglass. I have some lexan (polycarbonate) sitting in our garage waiting to be installed in our 2 entry doors and am going to take the screen door frames apart to do it.
Optix is a brand name of acrylic/plexiglass. Plexiglass versus polycarbonate. If you go to a plastics shop, they may have some leftover pieces that will work for less cost and they can cut it to size for you without scratching it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
