cmt246's avatar
cmt246
JT Strongarm Stabilizers
Would like to add these stabilizers to my unit , all pictures show the front tubes from landing gear up to a horizontal tube or frame between the gear
I don't have either I do have the steel fo the front cargo that the legs come thru ,
Is that stabil enough
How much force would is transferred to that area under load
Not much or enough that reinforcement should be added
Thanks
  • I bolted the front stabilizers to the front edge of the steel floor of the front storage compartment. Works fine. Mounting the brackets at the front bent edge of the steel floor provides plenty of support for the struts.
    For the rear, I have an enclosed underbelly, cannot see what is under it, and did not want to take it loose or cut it. So I added a piece of 2" x 2" square tube from one side of the frame to the other, and bolted the strut mounting brackets to that tube. Very sturdy. A metal fab shop could easily make one for you.
  • I added a piece of 3 x 3 x 1/4" angle iron from one side of the frame to the other side of the frame & bolted to the frame and it works great. :)
