Vintage465's avatar
Dec 26, 2017
Might add a third panel
So I need to move my solar panels around to add a Fantastic Vent over the bed. I always figured I'd add one more panel so I could have 450 watts of Solar. The reason I'd like to add one more panel is..........Just because that's how I roll. If two works fine then three should be even better.
Also because I've been kicking the idea about have the RV-Armor Roof Treatment done if/when I moved things around on the roof. So if I move things around I would like to get it all done so I do the RV-Armor Roof install once with the new lay out. So let's say I do this and I have 450w of Solar going through a 30a Samlex controller. I currently have two Interstate 6v in series. Would the 450w be enough to charge four 6v batteries?
We boondock for a week or so at a time and like to be able to live off the sun. We don't use any 110v appliances at all. No TV. The 12v system is pretty much used for lights and the Fantastic Vent/s, and two C-Pap machines . We do use the Forced Air Heater off 12v's when it's cold, and by cold I mean when i't like less than 30 degrees. Historically we've had no issues keeping the trailer warm at night and letting the Solar bring things back up during the day.
Thoughts?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,398 PostsLatest Activity: Oct 07, 2016
