1L243
Jun 10, 2021Explorer II
MORRYDE XFACTOR Cross brace Installed
A few weeks back I installed the Morryde CRE 3000 Suspension upgrade. I also planed to install the Morryde Xfactor Cross Brace which I did today. I ran into a little issue that might save anyone doing this in the future a little time.
When I installed the CRE 3000 I also installed the Wet Bolt Kit.
The Xfactor cross brace comes with a longer wet bolt. Which means I had to remove the Equalizer wet bolt(I only installed the Xfactor on the center equalizer bracket) that I had previously installed and replace it with the Xfactor wet bolt. Which means I had to jack up the trailer and remove the tires again.
Removing the wet bolt and installing the longer one is not difficult but if I had known I would have done it at the same time as the CRE 3000 and wet bolt install and saved myself a few hours.
The Xfactor was heavier than I thought.
I'm not sure what gauge the Xfactor channel is but the ends of the channel are closed with very thick steel. The new longer wet bolt bolts through the end plate thus needing the longer wet bolt. The kit also includes a upper metal strap for extra strength.
I have not towed with the new suspension yet but I am sure it will be a great improvement.
The only other thing I will add the instructions for the Xfactor calls for torquing the longer wet bolt at 40 pounds. The original wet bolt kit calls for torquing at 50 pounds. I went ahead and torqued it to 50 pounds the same as all the other wet bolts.
The center flange bolts on the channel are torqued at 40 pounds. The metal top strap is torqued at 15 pounds. I could not get a torque wrench on those bolts so I just used a 1/4" ratchet so not to over tighten.
