BurbMan
Apr 19, 2021Explorer II
Yes the pin nailer is good for trim work! I've found that doing anything that requires nailing through the interior luann wallboard will have the pin, brad or finish nail going clean through... My "go-to" tool for adding shelves or similar has become the narrow crown stapler The bridge of the staple prevents the fastener from sailing clean through the work and produces a stronger mechanical joint.
I've found that the air tools are much less expensive that battery powered and also provide a much smaller form factor to get into tight spaces in RVs. From where I park the RV I can get to anything with a 50' air hose.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
