mobeewan
Jan 19, 2014Explorer
If you have double sinks, one sink drain always runs horizontal at least 12 to 18 inches before connecting to the other sink drain going to the P-trap, so there shouldn't be a problem.
My sink has a large and small bowl. There is also a shelf under the entire sink area. The P-trap was under the larger sink which is on the left and positioned so that it ran immediately left leaving 40 percent of the shelf storage space under the sink useless. I cut the pipe, removed the glued in p-trap and flipped the drain pipes connecting to the sink drains 180 degrees. Then I put in a new P-trap on the right side with the P-trap pointing toward the wall. I added new pipe and additional elbows to run the pipe back to the wall and then along the wall. I also had to move the air admittance valve to the left rear corner and reconnected to the existing pipe. Gained back the 40 percent lost space.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
