TyroneandGladys wrote:
havasu wrote:
Thanks - I did check out Home Depot but they only have the single hose design and they don't work in an RV - it needs to be a dual hose.
In a basement the single would work great as it pulls the cooler air from the rest of the house.
Believe it or not the portable AC does not know if you have put it in a house a workshop a garage or a RV. If you do not believe me go get it from Home Depot put the window adapter that come with it in one of the windows in your RV the adapter will work on sliding windows, Run the single hose from the AC to the window adapter and you will see it works great, After seeing this then make your one permanent vent. If I am wrong, which I am not, and the AC does not work right return it to Home Depot.
I did that at my S&B and it worked great. I opted to run a small hose to basement to allow for the condensation from the AC.
On an RV, you can just let it drip onto the ground, it's just water.
Got tired of emptying the self-contained removable condensation container bin under the AC.
