Bigbird65
Nov 27, 2017Explorer
Replacing leaf spring suspension bushings
Probably some of you new to travel trailers are not aware of the need to replace the 14 suspension bushings on the dual axle trailers. I replaced these at 14,724 miles and should have replaced them by 10,000 miles at the latest. The original bushings were nylon and they wear out pretty quickly and cause metal to metal wear. I replaced them on our Winnebago 2101DS with Never Fail bushings (P/N LC279685) from etrailer.com They are also available on Amazon. etrailer has a pretty good installation video. Once you get setup with jack stands and jacks to support the brake assemblies the job is not too hard for the average mechanically inclined do-it-yourself-er. You can follow on this thread, how I did it starting on post #3069. There are a couple of pages of comments.
![](https://i.imgur.com/b0M39pIl.jpg)
