champdog's avatar
champdog
Solar charging maintaining help
Hi all, Ive got some questions. Ive been reading ALOT of posts and trying to gather knowledge of what other rvers are doing and using. I have calculated my useage while boondocking and have decided to purchase the GOPOWER 120w portable kit. Other than the propane fridge, the occasional water pump and the led bulbs, we have a 600w inverter to run a tv and dvd player. I have 2 group 31 lifeline agm's. My question is in maintaining while rv is in storage. Rv is parked outside but has a cover over it and is pretty far from shore power. I would like to charge/maintain using a small solar setup with either a single or dual station float charger. Dont want to have to set up the go power kit and leave it out for weeks or months at a time. So will one small solar panel and float charger be ok or am I better off taking cables loose seperating the parallel connection and using two different chargers, one on each battery. Looking to maintain the batteries the best way to get as much life as possible. Thanks
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
