bpounds
Oct 26, 2018Nomad
To add, the pic directly above is close to the max charge amps I have observed, about 18a @ 14.6v, or 250w out of the 400w rating panel sum. I am not sure if that is good or bad. It seems reasonable to me, considering they are flat mounted, and in the autumn season, and a high pv to battery amphr ratio.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Dec 11, 2017
