MaxAZ's avatar
MaxAZ
Tips on replacing vial trim around doors and compartments
My original factory trim that goes around the door moldings has faded and shrunk. I bought new narrow trim at Camp World but t doesn't like to stay in the molding pocket as it goes around curved corners. I've tried mild heat from a heat gun but it still pops out of the corners. Any tips to make this work better?
Here's the stuff I'm talking about.
http://m.campingworld.com/browse/skus/index.cfm?skunum=49675&rewrote&affiliateid=5193&gclid=CMzu_9nwvcoCFVBffgod9McJ1g
  • 4x4van's avatar
    4x4van
    Lynnmor wrote:
    One more thing, as you install the trim, don't stretch it. Try to push it together to get the most length in there. It shrinks soon enough.
    X2
  • One more thing, as you install the trim, don't stretch it. Try to push it together to get the most length in there. It shrinks soon enough.
  • Ok, sometimes the obvious just gets overlooked. I took a closer look at the trim and noticed the way the edges were beveled it could make a difference how it's installed. Once I flipped it over it stays in the groove nice and tight even on the corners. I guess they should have included instructions for people like me.
  • It is definitely right size. No way it could fit larger 1" size. And yeah, it does match the old stuff pretty close.
  • If it's popping out easily, you may be using the wrong sized insert. Try measuring the width of the old insert with it pressed flat.
