garyemunson
Mar 31, 2018Explorer II
Wanted to add an update to my experience with the Command Electronics 003-30 tail light gasket replacement. The new gaskets arrived but when I went to install them, I noticed the design of the light itself allows water into the back wall of the coach. The red plastic lens is not sealed to the black plastic body (the gasket seals the body to the coach) and rain is free to wash through the inside of the unit. This would not be an issue EXCEPT the bulbs mount from the bottom and there are holes for the wires to pass through and water is free to enter the coach wall there. Since the lens and back need to separate to replace bulbs, sealing the two together is not practical. May end up just buying better tail lights. Be far cheaper than rebuilding the back wall.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
