popeyemth's avatar
popeyemth
Wiring computer fans
Adding a couple fans to the exhaust stack on the fridge .
One has two wires, a black and a red so that's simple.
The other one has three wires, with one showing a short black tracer in the insulation. Would that be the negative lead with the other two hooked to positive?
Thanks in advance to the brain trust here. :)
Moderator edit to re-size picture to forum limit of 640px maximum width.
  • Ding Ding Ding we have a winner !!!
    The wire with marked insulation was the ground wire just as shown in the pic from 3.0Charlie.
    Thanks again,
    Mike
  • Yup. The third wire is the RPM feedback to the motherboard.
    Not needed for your application.
  • This is the R4 from Coolermaster. Typical computer fan with +/- leads, and the RPM tach.
    Good high-CFM fan, while quite noisy.
  • do a google search for computer fan wiring. I had a look, and there are images and explanations there.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 23, 2025
