06 keystone Raptor
Car49k
I know this topic has been discussed, however, I am trying to find out the tallest tire that I can put on my 2006 Keystone Raptor. I currently have ST225/75R15's and have had some blow outs with the cheap tires the manufacturer put on. I would like to put on 16's but not sure how big I can go. Any help please.
9 REPLIES 9
magilla70
When I had my Raptor I got 16" rims and ran LT225/75-16 Michelin XPS Ribs. Fit fine and no more worries.
2012 Dutchmen Voltage 3950 Epic w/full paint
2012 Ram 3500 Laramie Limited max tow w/4.10's
2004 Ford Excursion 6.0PSD not stock...
2011 Kawasaki Concours14 (mines)
2005 Honda VTX 1300C (hers):C
2btowed
Have an 07 DS 3612,put xps ribs on it.Had to buy 16in rims for the 215/75r16.Weight is ok since rig axles are 5500lbs.No rub,no touch,no FLATS,in 6 years.Just replaced them last summer before trip to Texas,on 2nd set.Pull great!!!
08 Ranger/sold/14 rzr900 4
08 Grizzly x2
06 400ex
06 Honda 90
08 f450
04 Kymco 110
TopSlink
I had an 08 changed to 16 inch rims and tires makes the gate about 3 inches higher but made a diff in towing and i felt allot safer with e rated tires
Badhabt
I have an 07 Raptor 3612...i too went with the Maxxis 15' M8008 E rated tires. Definately a beefier tire than the stock Ds, more square shouldered, really happy with them. Just an option if you dont want to buy new wheels
06 F350 4X4 Crew Cab Dually Tow Boss
07 Raptor 3612DS
06 Raptor 700R 50th Anniv Edition - mine
06 Wolverine 450 - wifes
13 Can Am Spyder ST-Limited - more mine
14 Can Am Spyder RT-S - more hers
BigDogF250
Tire diameter is the figure you want to keep in mind. All MFR's list that on the tire specs on their website. ANd you can easily measure from the ground to the top of your tire to see what yours are today.
You will find that a ST225/75R15 has a smaller diameter than a ST225/75R16 most of the time. My trailer had the axles flipped and over 7" between the tires (wheel to wheel) so I was able to go up in diameter.
Good Luck.
Don't take life too seriously, it's not permanent.
06 Weekend Warrior FSC3200, Axles flipped, Bridgestone Duravis Tires
2005 Ford F250 PSD 4x4
07 Yamaha YZF450 White/Silver, 94 Husqvarna WXC610
2008 Polaris RZR 800, 2011 Honda CBR1000RR & one Goffin Cockatoo
BarneyS
Moved to Toy Hauler forum from 5th wheels.
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
WhitehouseLV
this topic should probably be moved to the toyhauler forum, since the OP is asking specific about a toyhauler.
Longtime Member of RV.net (since 2005) just trying to find my friends and way around in this new community.
40' Keystone Toyhauler
2017 Ram 3500 DRW
2019 KTM 300 XC-W tpi
Honda CRF 80F
Honda Rincon
Polaris RZR 800 Trail
WhitehouseLV
we used to own a 2006 Keystone Raptor 3612DS that we purchased new. It came from the factory w/15" D rated tires. In 2007 or 2008 we put Maxxis E rated/10ply on...I think M8008. The neighbors own the toyhauler now and still have the original tires on it. It sits outside too. I'd recommend Maxxis for a 15" E rated tire.
If you want 16" you will need to upgrade your rims.
2017 Ram 3500 DRW
Honda CRF 80F
Honda Rincon
dcg9381
The best answer will be based on measuring your RV:
1) How much clearance do you have between the existing top of the tire and the deck of the rv?
2) How much clearance do you have between the wheels?
We can go from there...
How much does your rig weigh?
