โJun-25-2019 06:53 AM
โJun-30-2019 05:45 PM
valhalla360 wrote:That must be why you see so many reports of dead ecoboosts everywhere - Oh Wait - I haven't seen any such reports - must be a bunch of malarky.
Yes, the motor can put out those numbers but doing so really limits the duty rating.
โJun-30-2019 11:15 AM
patperry2766 wrote:rollindowntheroad wrote:
Ok I finally give!!! I understand that I wouldn't be able to tow a 5th wheel. With calculations I've come up with the max I could even tow a travel trailer is 7,000 lbs. A far cry from what Ford advertises.
That's not correct either. Per the 2019 Ford trailer towing guidelines and based on the info from your original post, max tow weight is 10,700 lbs
2019 Trailer Tow
look on page 19
โJun-30-2019 08:07 AM
โJun-30-2019 07:43 AM
mt1729 wrote:
Just to add a little bit more information. The ford 3.5 v6 ecoboost puts out 375 horsepower & 470 foot pounds of torque. How a little mostly aluminum engine of that size can handle twin turbos and that much power is mind boggling. However they seem to be holding up as well as any other gas engine that's out there.
โJun-30-2019 06:22 AM
โJun-30-2019 06:08 AM
โJun-30-2019 05:59 AM
2112 wrote:No one here can answer that question, only you can. But I'll give you my assesment. A reasonable estimate would be that 5th wheel has 1600 lbs ( give or take) of pin weight. If everything else in the truck weighs less than 400 lbs, per manufacturer's ratings you're good to go. If all in you're over your payload rating, it's up to you to decide if you're safe or not. In any event, it all won't crash an burn the minute you turn the key. Ulitimately, time could take a toll though.
So you're saying I can't do what I've been doing for the past 5 years? I'm shocked! Should I leave the FW at the beach and drive home without it? Rush to the dealer and pick up a 1 ton?
โJun-30-2019 05:20 AM
โJun-30-2019 04:45 AM
โJun-29-2019 11:53 PM
โJun-29-2019 08:49 PM
โJun-29-2019 04:44 PM
rollindowntheroad wrote:Bionic Man wrote:
If you havenโt bought the truck yet why are you so set on an F150?
Because those are in my price range. I don't want to spend $65,000 + on a truck.
โJun-28-2019 10:01 AM
Bionic Man wrote:That's your opinion, I've had both, in my experience I respectfully have a different opinion.
You have a much more reasonable approach - with the truck being a daily driver. OP is asking about a dedicated tow vehicle that he will full time in.
F250/2500 is a better choice, even if it is a little more.
โJun-28-2019 09:57 AM
โJun-28-2019 09:13 AM
troubledwaters wrote:
Actually I did just that in March. Depending on incentives in effect, the price is within a couple thousand dollars of each other. However, at least in March, the incentives for the F150 were $8500 more (cheaper) than the F250. And besides that, I have the 3.5 ecoboost and a 10 sp transmission, a combination that is far and away superior (in my opinion); And especially so if you are using it as a daily driver. I dumped my V10 F250 and couldn't be happier.
