jbeliera's avatar
jbeliera
2008 Laredo 29RL Grey tanks
I just picked up a 2008 Keystone Laredo 29RL and I see that the coach has two levers for grey tank drain. I have looked in various sources including their very generic owners manual, but I can not find why the second lever. Why the two levers if it only has one grey tank. confused
  • Thanks every one. I think the mystery valve has been explained
  • We had a 2007 29RL for years and it had 2 grey tanks and a black as Barney stated above. Each had a separate handle. Easy to test if you can hook up to water. Open one valve and turn on the kitchen sink and see if anything comes out. If not turn on the bathroom sink and you should get water out and you will know what handle goes to what tank.
  • My Laredo has two greys but it is an RK model. One grey tank for the kitchen and one grey tank for the bedroom area. Yours may be set up a little different but probably has two grey tanks also.
  • I suspect that one of the grey is for the kitchen sink. The other is for the bathroom sink and shower. The third is for the black tank. At least that is the way our travel trailer is set up.
    Barney
  • Sounds like you have two grays, one for shower and one for galley.
  • There are three levers and three stickers I pull one of the grey and nothing happens I pull another one and it has water The black is also active
