โAug-14-2014 06:11 PM
โAug-15-2014 10:02 AM
โAug-15-2014 09:51 AM
Golden_HVAC wrote:
Another thing.
Some new code requires that ark interrupting circuit breakers are used. These might trip due to the RV being plugged in. it is sort of like a GFI circuit breaker, however it detects arks, such as when a extension cord is sparking, and trips instantly, even at less than the amperage rating on the circuit breaker.
Fred.
โAug-15-2014 09:22 AM
Bumpyroad wrote:
for a every-now and then kind of thing, I wouldn't go the extra cost of a 50 amp hookup. just do a 30 amp supplying a 50 amp outlet.
bumpy
โAug-15-2014 09:09 AM
โAug-15-2014 07:33 AM
bumpy
โAug-15-2014 07:17 AM
โAug-15-2014 06:44 AM
Dave H M wrote:
Did we not look on the circuit breaker for grins and see what kind of circuit is present. :h
My garage is 20 and I get plenty of juice out of it to run the 13500 air.
โAug-15-2014 06:29 AM
โAug-15-2014 05:45 AM
โAug-15-2014 04:37 AM
โAug-15-2014 04:28 AM
โAug-14-2014 09:31 PM
โAug-14-2014 08:09 PM
โAug-14-2014 07:34 PM
โAug-14-2014 07:16 PM
nole_trainer wrote:Golden_HVAC wrote:
Hi,
The breaker is tripping at home. You are resetting it. Does the number on it say 15 or 20? I know I am getting pretty simple here, but you are asking for help, and not giving to much information.
What else in your home is off when the circuit breaker that you plugged the RV into is off? Does it shut off some lights, or all the bedroom circuits and the desktop computer, and other stuff with 5-8 amps running on it? That combined with it being a 15 amp circuit breaker, you only need the RV to use 7 amps to trip it.
If you can plug the RV into where the washing machine is plugged in, then it should be on it's very own 20 amp circuit breaker (NEC Code).
If your laundry room is really close to the driveway, and your dryer is electric, then it you could plug the RV into the 4 wire dryer receptacle. You would need to buy a 4 wire dryer cord (it will be 4 feet long) and a 50 amp flush mount stove range receptacle. It will look just like your RV cord end, and wire them together, you will have up to 30 amps 120/240 just like when plugged into a 50 amp service, except only 7,000 watts available, still you can run both A/C's with that adapter.
Fred.
No, I appreciate any/all help. I believe all my plugs in my garage are 15amp, so that sounds like the prob?
I'm done for the night, going to sweat it out with the boys!
If I have an electrician come out and add a plug, what do I need them to install? Do I just show him the sticker on the RV?
