Weldon
Jul 05, 2021Explorer
A leak at the drain valve
I have a leak at the drain valve on a Montana fifth wheel. It appears to be grey water and does not leak if the used lightly. I am about 50 miles from a dealer. I have not looked under the coroplast (sp.) to see if there is a gasket I need or possible just tighten some screws. Would appreciate learning what might be most likely part or parts to take with me when I go to make the repair.
Thanks!
Thanks!
